Aller au contenu principal
Nokia E61i Motherboard Replacement
Ce dont vous avez besoin
  1. Nokia E61i Motherboard Replacement, Battery: étape 1, image 1 de 2 Nokia E61i Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Motherboard Replacement: étape 2, image 1 de 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Motherboard Replacement: étape 3, image 1 de 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Motherboard Replacement, Front Cover: étape 4, image 1 de 2 Nokia E61i Motherboard Replacement, Front Cover: étape 4, image 2 de 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Motherboard Replacement: étape 5, image 1 de 1
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Motherboard Replacement, Display: étape 6, image 1 de 2 Nokia E61i Motherboard Replacement, Display: étape 6, image 2 de 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Motherboard Replacement: étape 7, image 1 de 2 Nokia E61i Motherboard Replacement: étape 7, image 2 de 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Nokia E61i Motherboard Replacement, Motherboard: étape 8, image 1 de 3 Nokia E61i Motherboard Replacement, Motherboard: étape 8, image 2 de 3 Nokia E61i Motherboard Replacement, Motherboard: étape 8, image 3 de 3
    • Pull the green motherboard from the back casing.
Christopher Patton
Membre depuis le 04/07/11
208 Réputation
12 tutoriels rédigés
Équipe
Cal Poly, Team 9-63, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 10
Total : 1,588
