Aller au contenu principal
Nokia E71x Camera Flash Replacement
Ce dont vous avez besoin
  1. Nokia E71x Camera Flash Replacement, Motherboard: étape 1, image 1 de 2 Nokia E71x Camera Flash Replacement, Motherboard: étape 1, image 2 de 2
    • Remove battery
  2. Nokia E71x Camera Flash Replacement: étape 2, image 1 de 1
    • Using Torx number 4 unscrew the four 0.5mm screws.
  3. Nokia E71x Camera Flash Replacement: étape 3, image 1 de 1
    • Push in four clips to detach the body.
  4. Nokia E71x Camera Flash Replacement: étape 4, image 1 de 3 Nokia E71x Camera Flash Replacement: étape 4, image 2 de 3 Nokia E71x Camera Flash Replacement: étape 4, image 3 de 3
    • Separate the body into two pieces.
    • Be careful not to damage the screen or body. Some force will be needed to separate the body.
  5. Nokia E71x Camera Flash Replacement: étape 5, image 1 de 3 Nokia E71x Camera Flash Replacement: étape 5, image 2 de 3 Nokia E71x Camera Flash Replacement: étape 5, image 3 de 3
    • Remove the bottom piece that is clipped on.
    • Some force will need to be exerted to remove the clip.
  6. Nokia E71x Camera Flash Replacement: étape 6, image 1 de 1
    • Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
  7. Nokia E71x Camera Flash Replacement: étape 7, image 1 de 2 Nokia E71x Camera Flash Replacement: étape 7, image 2 de 2
    • Once screws are removed detach back of phone from the motherboard.
    • This will require some force and maneuvering. Be careful not to break phone back or motherboard.
  8. Nokia E71x Camera Flash Replacement: étape 8, image 1 de 1
    • Replace motherboard, ensure that replacement has the same serial number.
  9. Nokia E71x Camera Flash Replacement, Camera Flash: étape 9, image 1 de 1
    • Camera is located on back of camera body.
    • To remove flash turn body over and gently tap on the case. The flash should fall out.
2 autres ont terminé cette réparation.
Will Goldby
Membre depuis le 08/29/11
187 Réputation
4 tutoriels rédigés
Équipe
Cuesta, Team 1-1, Zipperian Fall 2011 Membre de l'équipe Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 1,082
