Aller au contenu principal
Nokia E90 QWERTY Keyboard Replacement
Ce dont vous avez besoin
  1. Nokia E90 QWERTY Keyboard Replacement, Battery Cover and Battery: étape 1, image 1 de 1
    • In order to remove the back cover, you must press the indicated button.
  2. Nokia E90 QWERTY Keyboard Replacement: étape 2, image 1 de 2 Nokia E90 QWERTY Keyboard Replacement: étape 2, image 2 de 2
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
  3. Nokia E90 QWERTY Keyboard Replacement: étape 3, image 1 de 1
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
  4. Nokia E90 QWERTY Keyboard Replacement, Back Cover: étape 4, image 1 de 3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: étape 4, image 2 de 3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: étape 4, image 3 de 3
    • Using a plastic opening tool, separate the back cover from the phone.
  5. Nokia E90 QWERTY Keyboard Replacement: étape 5, image 1 de 2 Nokia E90 QWERTY Keyboard Replacement: étape 5, image 2 de 2
    • Continue along the edge with the plastic opening tool.
  6. Nokia E90 QWERTY Keyboard Replacement: étape 6, image 1 de 3 Nokia E90 QWERTY Keyboard Replacement: étape 6, image 2 de 3 Nokia E90 QWERTY Keyboard Replacement: étape 6, image 3 de 3
    • Gently, remove the back cover.
  7. Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: étape 7, image 1 de 3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: étape 7, image 2 de 3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: étape 7, image 3 de 3
    • Unscrew the indicated screws using the T5 screwdriver.
  8. Nokia E90 QWERTY Keyboard Replacement: étape 8, image 1 de 2 Nokia E90 QWERTY Keyboard Replacement: étape 8, image 2 de 2
    • Open the phone up and use the plastic opening tool to remove the cover to the keyboard.
    • Be careful not to break the plastic during this step; do your best not to force anything.
  9. Nokia E90 QWERTY Keyboard Replacement: étape 9, image 1 de 2 Nokia E90 QWERTY Keyboard Replacement: étape 9, image 2 de 2
    • The button board will be loose once the cover is removed.
    • Lift it up to reveal the sensor board.
  10. Nokia E90 QWERTY Keyboard Replacement: étape 10, image 1 de 2 Nokia E90 QWERTY Keyboard Replacement: étape 10, image 2 de 2
    • With the T5 Screwdriver, remove the marked screws.
  11. Nokia E90 QWERTY Keyboard Replacement: étape 11, image 1 de 2 Nokia E90 QWERTY Keyboard Replacement: étape 11, image 2 de 2
    • With the screws removed, the sensor board should be free to flip up.
  12. Nokia E90 QWERTY Keyboard Replacement: étape 12, image 1 de 2 Nokia E90 QWERTY Keyboard Replacement: étape 12, image 2 de 2
    • Disconnect the wire with the plastic opening tool.
  13. Nokia E90 QWERTY Keyboard Replacement: étape 13, image 1 de 3 Nokia E90 QWERTY Keyboard Replacement: étape 13, image 2 de 3 Nokia E90 QWERTY Keyboard Replacement: étape 13, image 3 de 3
    • Remove the screws marked.
    • The Screw on the left is located underneath the cable.
    • With those screws removed, the circuit board and sensor board will be detached from the rest of the phone.
4 autres ont terminé cette réparation.
Cameron Weinberg
Membre depuis le 04/12/11
567 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 18-21, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 11
30 derniers jours : 23
Total : 6,464
