Aller au contenu principal
Nokia Lumia 520 Battery Replacement
Ce dont vous avez besoin
  1. Nokia Lumia 520 Battery Replacement, Battery: étape 1, image 1 de 2 Nokia Lumia 520 Battery Replacement, Battery: étape 1, image 2 de 2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Battery Replacement: étape 2, image 1 de 2 Nokia Lumia 520 Battery Replacement: étape 2, image 2 de 2
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Battery Replacement: étape 3, image 1 de 2 Nokia Lumia 520 Battery Replacement: étape 3, image 2 de 2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
2 autres ont terminé cette réparation.
Kobina Faibille
Membre depuis le 11/03/15
156 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 Membre de l'équipe UMass Dartmouth, Team 1-5, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G5
3 membres
8 tutoriels rédigés
2 commentaires
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
beerwings1776 - Réponse
Greetings I have a Lumia & I need the Screen and Battery,so how can I get those 2?
Ayoba - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 3,628
