Introduction
Nokia Lumia 530 - RM-1017, RM-1019
How to disassemble / take apart the phone and change broken Display or Touch screen Glass Digitizer.
________________________ Video tutorial: ________________________
Ce dont vous avez besoin
Vidéo d'introduction
Turn off the phone.
Remove the battery and any installed SIM and memory cards. There are two tapes screws:
4x Torx T6
5x Torx T5
Remove the middle bezel.
Earpiece
Earpiece Flex Cable
Loudspeaker / Ringer
Disconnect the touch screen & display flex cable.
Remove the main board.
If the glass is broken, put some scotch tape to prevent it breake to pieces.
Use a hot air to make adhesive tape more soften.
Use a cutter and make small room to insert a plastic pick.
15 autres ont terminé cette réparation.
10 commentaires
What did you apply in the first frame of step 7? 4:15 in the video.
soldering flux
ZFix -
Thanks for confirming
I didn't end up doing it correctly - it didn't work.
I think the mistake I made was not heating the old flex cable off the connector. I didn't follow instructions correctly and I pulled it off. I was able to heat the leftover connectors off but after soldering the new flex onto the board and sealing up it didnt work - screen still unresponsive :-(
It was my first attempt at replacing a screen (and I don't have any experience) so I'm not too bummed.
I just ordered a complete LCD and digitizer instead :-)
Failed miserably... Soldering iron not adapted. Might want to emphasise that is critical. At least I tried...
