Aller au contenu principal
Nokia Lumia 635 Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. Nokia Lumia 635 Rear Facing Camera Replacement, Get Started - Open phone case: étape 1, image 1 de 2 Nokia Lumia 635 Rear Facing Camera Replacement, Get Started - Open phone case: étape 1, image 2 de 2
    • Open the back case of the phone using the plastic opening tool.
    • Remove the battery.
  2. Nokia Lumia 635 Rear Facing Camera Replacement, Screw removal: étape 2, image 1 de 2 Nokia Lumia 635 Rear Facing Camera Replacement, Screw removal: étape 2, image 2 de 2
    • Remove the six screws shown in the photo using the torx Screwdriver 5mm.
    • Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
  3. Nokia Lumia 635 Rear Facing Camera Replacement, Remove hidden screw: étape 3, image 1 de 1
    • Remove the black sticker on the bottom left side (As shown in the picture).
    • Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
  4. Nokia Lumia 635 Rear Facing Camera Replacement, Separating Back Cover From Screen: étape 4, image 1 de 1
    • Using the plastic opening tool separate the plastic cover from the screen.
    • On the top left corner you will see the screens flex attached to the mother bothered, watch out when separating them.
  5. Nokia Lumia 635 Rear Facing Camera Replacement, Camera Replacement: étape 5, image 1 de 1
    • Carefully retrieve the cameras flex as shown in the picture.
    • Attach the new camera’s flex to the mother board.
3 autres ont terminé cette réparation.
Alexa
Membre depuis le 10/07/14
455 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 7-1, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 7-1, Leahy Fall 2014
USFT-LEAHY-F14S7G1
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 2,083
