Aller au contenu principal
Nokia Lumia 900 Front Camera Replacement
Ce dont vous avez besoin
  1. Attention : l'étape 1 est issue d'un tutoriel marqué comme en cours.
    Nokia Lumia 900 Front Camera Replacement, Opening The Phone: étape 1, image 1 de 2 Nokia Lumia 900 Front Camera Replacement, Opening The Phone: étape 1, image 2 de 2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Front Camera Replacement, Detach Ribbon: étape 2, image 1 de 1
    • Detach camera ribbon from motherboard
  3. Nokia Lumia 900 Front Camera Replacement, Remove Camera: étape 3, image 1 de 1
    • Peel camera off of adhesive surface
    • Use caution when removing camera as it is fragile
  4. Nokia Lumia 900 Front Camera Replacement, Installing New Camera: étape 4, image 1 de 1
    • Apply adhesive to back of camera
    • Attach ribbon to motherboard
    • Press down on camera for 60 seconds
    • Let dry for 5 minutes
  5. Nokia Lumia 900 Front Camera Replacement, Reassembling Screen: étape 5, image 1 de 1
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
Joshua Crosman
Membre depuis le 10/20/14
304 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G1
3 membres
7 tutoriels rédigés
Un commentaire
Is also forgot to tell about the plate between screen and battery that is glued to the battery
John Bork - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 569
