Ce dont vous avez besoin
Étape 1 Opening The Phone
Attention : l'étape 1 est issue d'un tutoriel marqué comme en cours.
Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
Using the opening tool, pry the screen from the casing until they are separated from each other.
Detach connector from the phone.
Use the opening tool to pry out battery from the phone.
Detach Connectors that are attached from the screen to the motherboard.
Screen can now be removed with little effort.
Using a pair of tweezers, remove rubber gaskets that are holding the motherboard in place.
Starting in the bottom left corner of the device, insert a wedge between the motherboard and the case.
Gently pull up with the wedge allowing for the motherboard to gently click out of place.
Gradually repeat this process around the entire motherboard until it becomes easy enough to remove completley from the casing.
2 autres ont terminé cette réparation.
