Aller au contenu principal
Nokia Lumia 925 Motherboard Replacement
Ce dont vous avez besoin
  1. Nokia Lumia 925 Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Nokia Lumia 925 Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
    • Pull out the holder until it is completely separate.
    • Something like a paperclip will work if there are no tweezers available.
  2. Nokia Lumia 925 Motherboard Replacement: étape 2, image 1 de 3 Nokia Lumia 925 Motherboard Replacement: étape 2, image 2 de 3 Nokia Lumia 925 Motherboard Replacement: étape 2, image 3 de 3
    • Slide a plastic opening tool under the back cover.
    • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
    • Some pins are facing the opposite way from the others.
  3. Nokia Lumia 925 Motherboard Replacement: étape 3, image 1 de 3 Nokia Lumia 925 Motherboard Replacement: étape 3, image 2 de 3 Nokia Lumia 925 Motherboard Replacement: étape 3, image 3 de 3
    • Remove the 3 screws using the T7 Torx screwdriver.
    • Unclip the black tab connector.
  4. Nokia Lumia 925 Motherboard Replacement: étape 4, image 1 de 2 Nokia Lumia 925 Motherboard Replacement: étape 4, image 2 de 2
    • Remove the silver metal cover.
    • Be careful of the tape under the right square side of the panel. Using a spudger helps.
  5. Nokia Lumia 925 Motherboard Replacement: étape 5, image 1 de 3 Nokia Lumia 925 Motherboard Replacement: étape 5, image 2 de 3 Nokia Lumia 925 Motherboard Replacement: étape 5, image 3 de 3
    • Unclip the two orange tabs.
    • Remove the four silver screws using the T5 Torx screwdriver.
  6. Nokia Lumia 925 Motherboard Replacement: étape 6, image 1 de 2 Nokia Lumia 925 Motherboard Replacement: étape 6, image 2 de 2
    • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
Joseph McCoy
Membre depuis le 09/18/18
235 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 23
Total : 760
