Aller au contenu principal
Nokia Lumia 930 Motherboard Replacement
Ce dont vous avez besoin
  1. Nokia Lumia 930 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Pull the SIM card holder out of the top of the phone using your fingernail.
  2. Nokia Lumia 930 Motherboard Replacement: étape 2, image 1 de 2 Nokia Lumia 930 Motherboard Replacement: étape 2, image 2 de 2
    • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
  3. Nokia Lumia 930 Motherboard Replacement: étape 3, image 1 de 2 Nokia Lumia 930 Motherboard Replacement: étape 3, image 2 de 2
    • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
  4. Nokia Lumia 930 Motherboard Replacement: étape 4, image 1 de 1
    • Remove the 4mm Torx #4 screw that's securing the battery connector.
  5. Nokia Lumia 930 Motherboard Replacement: étape 5, image 1 de 1
    • Use tweezers to remove the battery connector strap.
  6. Nokia Lumia 930 Motherboard Replacement: étape 6, image 1 de 2 Nokia Lumia 930 Motherboard Replacement: étape 6, image 2 de 2
    • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
  7. Nokia Lumia 930 Motherboard Replacement: étape 7, image 1 de 3 Nokia Lumia 930 Motherboard Replacement: étape 7, image 2 de 3 Nokia Lumia 930 Motherboard Replacement: étape 7, image 3 de 3
    • Use the flat end of a spudger to pry the battery cover from the phone's frame.
  8. Nokia Lumia 930 Motherboard Replacement: étape 8, image 1 de 1
    • Pull up on the heat spreader.
    • Be careful not to tear it!
  9. Nokia Lumia 930 Motherboard Replacement: étape 9, image 1 de 1
    • Use the flat end of the spudger to lift up the battery.
    • The battery is glued in place. Pry up carefully, not to damage it.
    • Two flex cables are directly underneath the battery.
  10. Nokia Lumia 930 Motherboard Replacement: étape 10, image 1 de 1
    • Remove the battery from the phone.
  11. Nokia Lumia 930 Motherboard Replacement, Motherboard: étape 11, image 1 de 2 Nokia Lumia 930 Motherboard Replacement, Motherboard: étape 11, image 2 de 2
    • Use the flat end of a spudger to disconnect the camera connectors.
    • Pull the camera up and out to remove it from the phone.
  12. Nokia Lumia 930 Motherboard Replacement: étape 12, image 1 de 1
    • Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
  13. Nokia Lumia 930 Motherboard Replacement: étape 13, image 1 de 3 Nokia Lumia 930 Motherboard Replacement: étape 13, image 2 de 3 Nokia Lumia 930 Motherboard Replacement: étape 13, image 3 de 3
    • Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
    • Remove the orange flex cable from the phone.
  14. Nokia Lumia 930 Motherboard Replacement: étape 14, image 1 de 1
    • Repeat the previous step for the black jumper flex cable under the battery.
  15. Nokia Lumia 930 Motherboard Replacement: étape 15, image 1 de 2 Nokia Lumia 930 Motherboard Replacement: étape 15, image 2 de 2
    • Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
    • Remove the antenna.
  16. Nokia Lumia 930 Motherboard Replacement: étape 16, image 1 de 1
    • Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
    • Apply new adhesive when reassembling the phone.
  17. Nokia Lumia 930 Motherboard Replacement: étape 17, image 1 de 3 Nokia Lumia 930 Motherboard Replacement: étape 17, image 2 de 3 Nokia Lumia 930 Motherboard Replacement: étape 17, image 3 de 3
    • Use a spudger to pry up the bottom end of the motherboard, then pull it out.
2 autres ont terminé cette réparation.
Josiah Sweatt
Membre depuis le 02/21/18
571 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 1,089
