Aller au contenu principal
Nokia N70 Keypad Replacement
Ce dont vous avez besoin
  1. Nokia N70 Keypad Replacement, Battery: étape 1, image 1 de 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Keypad Replacement: étape 2, image 1 de 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Keypad Replacement: étape 3, image 1 de 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Keypad Replacement: étape 4, image 1 de 1
    • Remove the battery from the phone.
  5. Nokia N70 Keypad Replacement, Keypad: étape 5, image 1 de 3 Nokia N70 Keypad Replacement, Keypad: étape 5, image 2 de 3 Nokia N70 Keypad Replacement, Keypad: étape 5, image 3 de 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Keypad Replacement: étape 6, image 1 de 3 Nokia N70 Keypad Replacement: étape 6, image 2 de 3 Nokia N70 Keypad Replacement: étape 6, image 3 de 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
Justin
Membre depuis le 10/12/11
984 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-2, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 membres
10 tutoriels rédigés
Un commentaire
I have N70 nokia mobile. Its keypad buttons 1, 2 & C and also left key and upper key is not working
please give me solution how to solve this problem
Imamuddin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 3,993
