Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nokia XL Dual SIM Motherboard Replacement
Ce dont vous avez besoin
  1. Nokia XL Dual SIM Motherboard Replacement, Back Cover Removal: étape 1, image 1 de 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual SIM Motherboard Replacement, Battery Removal: étape 2, image 1 de 2 Nokia XL Dual SIM Motherboard Replacement, Battery Removal: étape 2, image 2 de 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual SIM Motherboard Replacement, Screen Separation part 1: étape 3, image 1 de 2 Nokia XL Dual SIM Motherboard Replacement, Screen Separation part 1: étape 3, image 2 de 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual SIM Motherboard Replacement, Screen Separation part 2: étape 4, image 1 de 3 Nokia XL Dual SIM Motherboard Replacement, Screen Separation part 2: étape 4, image 2 de 3 Nokia XL Dual SIM Motherboard Replacement, Screen Separation part 2: étape 4, image 3 de 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual SIM Motherboard Replacement, System components: étape 5, image 1 de 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual SIM Motherboard Replacement, Removing Connectors: étape 6, image 1 de 2 Nokia XL Dual SIM Motherboard Replacement, Removing Connectors: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • With tweezers, gently unsnap the motherboard connectors for all components.
    • The location of all the connectors is indicated in the next step.
  7. Nokia XL Dual SIM Motherboard Replacement, Connector Locations: étape 7, image 1 de 3 Nokia XL Dual SIM Motherboard Replacement, Connector Locations: étape 7, image 2 de 3 Nokia XL Dual SIM Motherboard Replacement, Connector Locations: étape 7, image 3 de 3
    • The 3 motherboard connectors for the touchscreen, volume buttons, and power/screen lock button assembly are indicated on the picture.
    • The touchscreen assembly can now be removed and set aside.
    • The motherboard connector for the front camera is indicated on the picture.
    • The motherboard connector for the camera flash, vibrator, and headphone jack assembly is indicated in the picture.
  8. Nokia XL Dual SIM Motherboard Replacement, Remove motherboard: étape 8, image 1 de 2 Nokia XL Dual SIM Motherboard Replacement, Remove motherboard: étape 8, image 2 de 2
    • Gently pry up on the top underside of the motherboard with the small plastic opening tool.
    • Gently pulling upward on the motherboard will allow it to be removed.
8 autres ont terminé cette réparation.
Christopher Weaver
Membre depuis le 09/25/14
984 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 membres
7 tutoriels rédigés
3 commentaires de tutoriel
I removed my charging system while removing the charger from the phone after that i sgave it to phone repaire to insert a new charging system ,When my phone was ready he gave it to me,After i switched it on it turned bluish incolour the whole screen,so what can i do pls?
jmwachofi8 - Réponse
My phone is not charging when I plug it on the wall you ll see the charging indication on the battle sign on the phone that it is charging but it won't from morning to the next day it ll not what should i do,please
John - Réponse
My nokia xL was plugged in a big battery of Inverter and was switched off and after that it stops working
Sahil ali - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 31
Total : 8,571
