Aller au contenu principal
Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement
Ce dont vous avez besoin
  1. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Back Cover Removal: étape 1, image 1 de 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Battery Removal: étape 2, image 1 de 2 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Battery Removal: étape 2, image 2 de 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 1: étape 3, image 1 de 2 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 1: étape 3, image 2 de 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: étape 4, image 1 de 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: étape 4, image 2 de 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: étape 4, image 3 de 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, System components: étape 5, image 1 de 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: étape 6, image 1 de 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: étape 6, image 2 de 3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Gently unsnap the 3 motherboard connectors for the touch screen assembly with tweezers.
    • The touch screen, volume buttons, and power/screen lock button assembly can now be removed.
16 autres ont terminé cette réparation.
Christopher Weaver
Membre depuis le 09/25/14
984 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 membres
7 tutoriels rédigés
Un commentaire
next pic i whant this information touch change....
prakash prakash - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 16,054
