Aller au contenu principal
Nokia XL Dual Sim Front Camera Replacement
Ce dont vous avez besoin
  1. Nokia XL Dual Sim Front Camera Replacement, Back Cover Removal: étape 1, image 1 de 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual Sim Front Camera Replacement, Battery Removal: étape 2, image 1 de 2 Nokia XL Dual Sim Front Camera Replacement, Battery Removal: étape 2, image 2 de 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: étape 3, image 1 de 2 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: étape 3, image 2 de 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: étape 4, image 1 de 3 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: étape 4, image 2 de 3 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: étape 4, image 3 de 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual Sim Front Camera Replacement, System components: étape 5, image 1 de 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual Sim Front Camera Replacement, Camera Removal: étape 6, image 1 de 3 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: étape 6, image 2 de 3 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • With Tweezers, gently unsnap the front camera motherboard connector.
    • The front camera component can now be gently removed.
6 autres ont terminé cette réparation.
Shadeed Bilal
Membre depuis le 09/25/14
231 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 membres
7 tutoriels rédigés
1 commentaire de tutoriel
merci 1000 fois pour ce cite
zmohye - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 1,192
