Aller au contenu principal
Noma Pedestal Fan Blade Replacement
Ce dont vous avez besoin
  1. Noma Pedestal Fan Blade Replacement, Fan Blade: étape 1, image 1 de 2 Noma Pedestal Fan Blade Replacement, Fan Blade: étape 1, image 2 de 2
    • Undo the clips on the outer edge of the fan.
    • Make sure the fan is disconnected from the power source before starting.
  2. Noma Pedestal Fan Blade Replacement: étape 2, image 1 de 2 Noma Pedestal Fan Blade Replacement: étape 2, image 2 de 2
    • Gently remove the front piece by pulling it towards the bottom.
    • Don't pull too hard to avoid damaging the clips on the fan.
  3. Noma Pedestal Fan Blade Replacement: étape 3, image 1 de 1
    • Turn the cap clockwise and remove it.
  4. Noma Pedestal Fan Blade Replacement: étape 4, image 1 de 3 Noma Pedestal Fan Blade Replacement: étape 4, image 2 de 3 Noma Pedestal Fan Blade Replacement: étape 4, image 3 de 3
    • Lightly pull the faulty blade towards you.
    • Be careful while pulling to not injure yourself.
  5. Noma Pedestal Fan Blade Replacement: étape 5, image 1 de 2 Noma Pedestal Fan Blade Replacement: étape 5, image 2 de 2
    • Insert the new fan blade onto the screw .
    • Make sure it's pushed all the way back.
  6. Noma Pedestal Fan Blade Replacement: étape 6, image 1 de 2 Noma Pedestal Fan Blade Replacement: étape 6, image 2 de 2
    • Place the cap on the screw and tighten it by turning counterclockwise.
  7. Noma Pedestal Fan Blade Replacement: étape 7, image 1 de 2 Noma Pedestal Fan Blade Replacement: étape 7, image 2 de 2
    • After placing the front piece back on, fasten the clips again.
    • Make sure you align the piece to fit perfectly on the top.
This is a relatively easy process and as long as you follow our step-by-step guide it should be easy to fix.
Taha Hashmi
Membre depuis le 01/15/24
172 Réputation
1 tutoriel rédigé
Équipe
York University, Team P-6, O'Regan Winter 2024 Membre de l'équipe York University, Team P-6, O'Regan Winter 2024
YORK-O'REGAN-W24SPG6
2 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 30
Total : 371
