Aller au contenu principal
Nook HD+ Charging Port Replacement
Ce dont vous avez besoin
  1. Nook HD+ Charging Port Replacement, Motherboard: étape 1, image 1 de 3 Nook HD+ Charging Port Replacement, Motherboard: étape 1, image 2 de 3 Nook HD+ Charging Port Replacement, Motherboard: étape 1, image 3 de 3
    • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
    • Pop up all plastic tabs that secure the frame to the chassis.
  2. Nook HD+ Charging Port Replacement: étape 2, image 1 de 3 Nook HD+ Charging Port Replacement: étape 2, image 2 de 3 Nook HD+ Charging Port Replacement: étape 2, image 3 de 3
    • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
    • Disconnect battery from motherboard.
    • Remove back casing.
  3. Nook HD+ Charging Port Replacement: étape 3, image 1 de 2 Nook HD+ Charging Port Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
    • Use tweezers to lift the flaps.
  4. Nook HD+ Charging Port Replacement: étape 4, image 1 de 1
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
    • No tool is needed. Gently pull on the wires until the piece disconnects.
  5. Nook HD+ Charging Port Replacement: étape 5, image 1 de 1
    • Disconnect antenna from motherboard by pulling up with slight force.
  6. Nook HD+ Charging Port Replacement: étape 6, image 1 de 2 Nook HD+ Charging Port Replacement: étape 6, image 2 de 2
    • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
    • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
  7. Nook HD+ Charging Port Replacement: étape 7, image 1 de 2 Nook HD+ Charging Port Replacement: étape 7, image 2 de 2
    • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
    • Remove the motherboard.
  8. Nook HD+ Charging Port Replacement, Charging Port: étape 8, image 1 de 2 Nook HD+ Charging Port Replacement, Charging Port: étape 8, image 2 de 2
    • Once removing the motherboard, flip it over and locate the charging port. Use a soldering iron to disconnect the charging port from the motherboard. If confused here's a reference.
    • Since the charging port is attached to the motherboard, it is simpler to replace both.
    • Soldering iron will be very hot and can both burn your hand and possibly damage the device.
    • Solder the new charging port to the motherboard.
Bayleigh Fouts
Membre depuis le 03/31/22
97 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 3-3, Harley Spring 2022 Membre de l'équipe IUPUI, Team 3-3, Harley Spring 2022
IUPUI-HARLEY-S22S3G3
3 membres
3 tutoriels rédigés
Un commentaire
Where can I obtain the replacement part?? the new charging port???
Jim Rhem - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 26
Total : 712
