Introduction
This guide will show easy ways to access the nook tablet visual display, replace the screen or reconnect the display if it is not working properly.
Ce dont vous avez besoin
Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
Lift up the foam pad at the corner of the battery to reveal the battery connector.
Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
Lift up the foam that covers the power connector and volume connector.
Disconnect the power and volume cables from their sockets on the motherboard.
Orient the mother board as shown, so that the screen is facing downwards.
Grab the corner of the orange strip on the right side of the mother board as shown.
The orange strip is adhered to the mother board, gently lift the strip so that the adhesion is broken.
The strip will still be attached by the circuit connection to the mother board, proceed to the next step.
12 autres ont terminé cette réparation.
