Aller au contenu principal
Nook Tablet Speaker Assembly Replacement
Ce dont vous avez besoin
  1. Nook Tablet Speaker Assembly Replacement, Back Cover: étape 1, image 1 de 1
    • Flip the Nook over.
  2. Nook Tablet Speaker Assembly Replacement: étape 2, image 1 de 2 Nook Tablet Speaker Assembly Replacement: étape 2, image 2 de 2
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
  3. Nook Tablet Speaker Assembly Replacement: étape 3, image 1 de 2 Nook Tablet Speaker Assembly Replacement: étape 3, image 2 de 2
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Speaker Assembly Replacement: étape 4, image 1 de 2 Nook Tablet Speaker Assembly Replacement: étape 4, image 2 de 2
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Speaker Assembly Replacement: étape 5, image 1 de 1
    • Pull the back panel off the Nook.
  6. Nook Tablet Speaker Assembly Replacement, Screen Bezel: étape 6, image 1 de 2 Nook Tablet Speaker Assembly Replacement, Screen Bezel: étape 6, image 2 de 2
    • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
  7. Nook Tablet Speaker Assembly Replacement: étape 7, image 1 de 2 Nook Tablet Speaker Assembly Replacement: étape 7, image 2 de 2
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  8. Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: étape 8, image 1 de 2 Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: étape 8, image 2 de 2
    • Lift up the foam pad at the corner of the battery to reveal the battery connector.
    • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
  9. Nook Tablet Speaker Assembly Replacement, Midframe: étape 9, image 1 de 1
    • Lift up the foam that covers the power connector and volume connector.
    • Disconnect the power and volume cables from their sockets on the motherboard.
  10. Nook Tablet Speaker Assembly Replacement: étape 10, image 1 de 2 Nook Tablet Speaker Assembly Replacement: étape 10, image 2 de 2
    • Carefully lift the silver midframe away from the motherboard and display assembly.
    • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
  11. Nook Tablet Speaker Assembly Replacement, Removing Speaker Assembly: étape 11, image 1 de 1
    • Using your hands pull the square speaker assembly component off the motherboard.
  12. Nook Tablet Speaker Assembly Replacement, Replacing Speaker Assembly: étape 12, image 1 de 1
    • Now place the new speaker assembly component back in the same square location.
    • As Step 12 mentions, make sure to realign the speaker assembly correctly in the square.
Josh Fisher
Membre depuis le 09/26/12
9 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 1-4, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,089
