Aller au contenu principal
Nortel Networks i2004 IP Back Cover Replacement
Ce dont vous avez besoin
  1. Nortel Networks i2004 IP Back Cover Replacement, Back Cover: étape 1, image 1 de 3 Nortel Networks i2004 IP Back Cover Replacement, Back Cover: étape 1, image 2 de 3 Nortel Networks i2004 IP Back Cover Replacement, Back Cover: étape 1, image 3 de 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Back Cover Replacement: étape 2, image 1 de 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Back Cover Replacement: étape 3, image 1 de 2 Nortel Networks i2004 IP Back Cover Replacement: étape 3, image 2 de 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Back Cover Replacement: étape 4, image 1 de 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Back Cover Replacement: étape 5, image 1 de 2 Nortel Networks i2004 IP Back Cover Replacement: étape 5, image 2 de 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
Elizabeth
Membre depuis le 01/21/12
160 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-35, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,202
