Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
If you can't hear the other line, then your speaker is broken. Use this guide in order to replace the damaged speakerphone speaker.
  1. Flip the phone over to view the back. Remove the power and phone cords. Remove the power and phone cords.
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Remove the seven 8mm Phillips #2 screws.
    • Remove the seven 8mm Phillips #2 screws.
  3. Lift up the back cover slowly because there are still wires attached to the circuit board. Lifting the back cover should not require a lot of force; simply lift with your fingertips.
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  6. Remove the six 8mm Phillips #2 screws. Pull the speaker phone cover straight up.
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  7. Lift the speaker straight up.
    • Lift the speaker straight up.
    • The speaker may need to be slightly wiggled in order to loosen and remove.
  8. Cut the red and white wires as close to the speaker as possible.
    • Cut the red and white wires as close to the speaker as possible.
    • Wire cutters are preferred, but normal scissors are fine too.
  9. Solder wires to new speaker. Solder wires to new speaker.
    • Solder wires to new speaker.
Elizabeth
Membre depuis le 21/01/2012
160 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-35, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 984
