Introduction
This guide will teach the user how to install a new motor for the device.
Now that the power switch is disconnected from the popper, you will need to remove the white top.
Gently remove the heating component from the popper.
Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
Now that the white top is disconnected from the housing, remove the heating component from inside the device.
Unscrew the two screws (2.5mm #0 Philips screws) that connect the motor to the fan base using the #0 Philips screwdriver.
Remove the motor from the fan base.
