Aller au contenu principal
Nostalgia Electrics RHP-310 Power Switch Replacement
Ce dont vous avez besoin
  1. Nostalgia Electrics RHP-310 Power Switch Replacement, Power Switch: étape 1, image 1 de 1
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Power Switch Replacement: étape 2, image 1 de 1
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Power Switch Replacement: étape 3, image 1 de 1
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Power Switch Replacement: étape 4, image 1 de 2 Nostalgia Electrics RHP-310 Power Switch Replacement: étape 4, image 2 de 2
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Power Switch Replacement: étape 5, image 1 de 1
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Power Switch Replacement: étape 6, image 1 de 1
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
Dana Clarke
Membre depuis le 09/26/12
50 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 16-57, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 16-57, Forte Fall 2012
CPSU-FORTE-F12S16G57
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 17
Total : 1,064
