Introduction
This guide will outline how to replace the fan inside the heating component.
Outils
Pièces
Aucune pièce spécifiée.
Now that the power switch is disconnected from the popper, you will need to remove the white top.
Gently remove the heating component from the popper.
Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
Now that the white top is disconnected from the housing, remove the heating component from inside the device.
Presque terminé !
