Aller au contenu principal
Novatel MiFi 2200 Battery Replacement
Ce dont vous avez besoin
  1. Novatel MiFi 2200 Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Battery Replacement: étape 2, image 1 de 1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Battery Replacement: étape 3, image 1 de 1
    • Insert the new battery into the battery slot.
    • Make sure to place the battery in with the white arrows facing inward.
  4. Novatel MiFi 2200 Battery Replacement: étape 4, image 1 de 2 Novatel MiFi 2200 Battery Replacement: étape 4, image 2 de 2
    • Re-install the rear cover by placing the inward end in it's slot.
    • Push down on the cover while sliding it into the slot to snap it back into place.
Charge your new battery and you are ready to use your Mifi again.
Carissah
Membre depuis le 04/15/12
147 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-36, Maness Spring 2012 Membre de l'équipe Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,014
