Aller au contenu principal
Novatel MiFi 2200 Case Replacement
Ce dont vous avez besoin
  1. Novatel MiFi 2200 Case Replacement, Battery: étape 1, image 1 de 1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Case Replacement: étape 2, image 1 de 1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Case Replacement, Case: étape 3, image 1 de 1
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Case Replacement: étape 4, image 1 de 1
    • Once the seal has been broken all the way around, open the cases using your hands.
2 autres ont terminé cette réparation.
Justin Russo
Membre depuis le 04/15/12
196 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-36, Maness Spring 2012 Membre de l'équipe Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 membres
5 tutoriels rédigés
Un commentaire
If case gets damaged, is there a place to but the case
Snehraj Merchant - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,529
