Introduction
If major problems occur with the device and problems still can not be fixed after following troubleshooting guides, there may be a circuit board issue. This guide gives instructions on how to replace a broken circuit board.
Pièces
Aucune pièce nécessaire.
Remove the rear cover by pressing down on the cover and pulling it away from the device.
  • Remove the rear cover by pressing down on the cover and pulling it away from the device.
Ajouter un commentaire
Place your finger on the back of the battery located near the edge of the device.
  • Place your finger on the back of the battery located near the edge of the device.
  • Push your finger into the battery and lift up to pop the battery out of the device.
  • Using a metal spudger, pry open the device around the seam between the front and back cover.
  • It may be difficult to split apart, so use force with caution.
  • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  • Once the seal has been broken all the way around, open the cases using your hands.
  • To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
  • Simply pick up the circuit board with your fingers and remove it from the case.
  • Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed.
  • Snap the two halves together along the adhesive line to reconnect it as it previously was.
After the circuit board is replaced the device should function properly again. When reassembling the device, keep in mind that you will need adhesive to keep the device together.
6 autre(s) ont terminé cette réparation.
Justin Russo
Membre depuis le 15/04/2012
196 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-36, Maness Spring 2012 Membre de l'équipe Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 membres
5 tutoriels rédigés
Hello, where do you purchase the new circuit board?
David - Réponse
I've tried every thing to get this device to work properly. Sic results. Sic.
Clennis Jones - Réponse
Where and how can I get this thing replaced?
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 1,927
