Aller au contenu principal
NuVision 10.1 Atom Motherboard Replacement
Ce dont vous avez besoin
  1. NuVision 10.1 Atom Motherboard Replacement, Camera: étape 1, image 1 de 3 NuVision 10.1 Atom Motherboard Replacement, Camera: étape 1, image 2 de 3 NuVision 10.1 Atom Motherboard Replacement, Camera: étape 1, image 3 de 3
    • Turn the device screen side down.
    • Carefully remove the back piece with the iFixit opening tool.
  2. NuVision 10.1 Atom Motherboard Replacement: étape 2, image 1 de 1
    • Remove the yellow tape covering the motherboard gently with your fingers.
  3. NuVision 10.1 Atom Motherboard Replacement: étape 3, image 1 de 3 NuVision 10.1 Atom Motherboard Replacement: étape 3, image 2 de 3 NuVision 10.1 Atom Motherboard Replacement: étape 3, image 3 de 3
    • Pull the camera plug upward and away from the motherboard with your fingers.
    • Gently pull the camera from the device. The camera is held by tension.
  4. NuVision 10.1 Atom Motherboard Replacement, Speaker: étape 4, image 1 de 1
    • Carefully remove silver tape with your fingers.
  5. NuVision 10.1 Atom Motherboard Replacement: étape 5, image 1 de 2 NuVision 10.1 Atom Motherboard Replacement: étape 5, image 2 de 2
    • Remove speakers gently using your fingers, they pop out easily.
    • Disconnect cords attached to the speaker from white pod.
  6. NuVision 10.1 Atom Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
  7. NuVision 10.1 Atom Motherboard Replacement: étape 7, image 1 de 3 NuVision 10.1 Atom Motherboard Replacement: étape 7, image 2 de 3 NuVision 10.1 Atom Motherboard Replacement: étape 7, image 3 de 3
    • Gently remove the battery's three ZIF connectors from the motherboard. Use your fingers.
    • Be careful not to puncture the battery.
  8. NuVision 10.1 Atom Motherboard Replacement: étape 8, image 1 de 2 NuVision 10.1 Atom Motherboard Replacement: étape 8, image 2 de 2
    • Disconnect the battery's bundled cable connector from the motherboard with fingers.
  9. NuVision 10.1 Atom Motherboard Replacement: étape 9, image 1 de 3 NuVision 10.1 Atom Motherboard Replacement: étape 9, image 2 de 3 NuVision 10.1 Atom Motherboard Replacement: étape 9, image 3 de 3
    • Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily.
Laila Schulz
Membre depuis le 02/14/19
219 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S1-G5, Leahy Spring 2019 Membre de l'équipe USF Tampa, Team S1-G5, Leahy Spring 2019
USFT-LEAHY-S19S1G5
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 13
Total : 452
