Aller au contenu principal
NuVision Duo 11 Battery Replacement
Ce dont vous avez besoin
  1. NuVision Duo 11 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
    • Slide the spudger down each side until you hear numerous clicks.
    • Remove the back panel from the tablet.
  2. NuVision Duo 11 Battery Replacement, Battery: étape 2, image 1 de 2 NuVision Duo 11 Battery Replacement, Battery: étape 2, image 2 de 2
    • Carefully remove any pieces of electrical tape that may be adhered to the battery.
    • The tape may be adhered to wires; be sure to pull up the tape slowly.
  3. NuVision Duo 11 Battery Replacement: étape 3, image 1 de 1
  4. NuVision Duo 11 Battery Replacement: étape 4, image 1 de 1
    • Gently peel the battery from the front case.
    • You will be met with some resistance, so it is critical that you are very careful.
    • DO NOT puncture or bend the battery. It may explode or leak toxic chemicals.
Gavin Amaral
Membre depuis le 03/16/23
377 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023 Membre de l'équipe UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 10
Total : 229
