Aller au contenu principal
Nutri Ninja BL450 Plastic Outer Base Replacement
Ce dont vous avez besoin
  1. Nutri Ninja BL450 Plastic Outer Base Replacement, Small Rubber Wheel: étape 1, image 1 de 1
    • Remove the cup from the blender base.
  2. Nutri Ninja BL450 Plastic Outer Base Replacement: étape 2, image 1 de 2 Nutri Ninja BL450 Plastic Outer Base Replacement: étape 2, image 2 de 2
    • Turn the blender over and unscrew the three 14 mm screws holding the slotted base in place. These are Torx Security bits (TR9) on some units.
  3. Nutri Ninja BL450 Plastic Outer Base Replacement: étape 3, image 1 de 3 Nutri Ninja BL450 Plastic Outer Base Replacement: étape 3, image 2 de 3 Nutri Ninja BL450 Plastic Outer Base Replacement: étape 3, image 3 de 3
    • Using a the standard Phillips head screwdriver bit, remove the slotted black plastic covering and then unscrew the one 11mm screw holding the power cord in place.
    • Unscrew the four 14 mm screws that are in the deep slots. This will release the motor from the base.
  4. Nutri Ninja BL450 Plastic Outer Base Replacement: étape 4, image 1 de 3 Nutri Ninja BL450 Plastic Outer Base Replacement: étape 4, image 2 de 3 Nutri Ninja BL450 Plastic Outer Base Replacement: étape 4, image 3 de 3
    • CAUTION: the silver blade attached to the motor is very sharp. Use a towel or thick cloth to protect your hands for the next step.
    • Using a towel, hold the silver fan still. Twist the small black rubber wheel that is attached to the top of the blender base to the right. This will remove the wheel for replacement.
  5. Nutri Ninja BL450 Plastic Outer Base Replacement, Plastic Outer Base: étape 5, image 1 de 3 Nutri Ninja BL450 Plastic Outer Base Replacement, Plastic Outer Base: étape 5, image 2 de 3 Nutri Ninja BL450 Plastic Outer Base Replacement, Plastic Outer Base: étape 5, image 3 de 3
    • Use the standard Phillips head screw bit to unscrew the screws in the black plastic with the silver circular discs.
    • Using the T9 screw bit, unscrew the four sets of two 11 mm screws located on each of the four sides of the motor.
  6. Nutri Ninja BL450 Plastic Outer Base Replacement: étape 6, image 1 de 2 Nutri Ninja BL450 Plastic Outer Base Replacement: étape 6, image 2 de 2
    • Untwist the small rubber connector to detach the plastic from the motor.
Morgan Blauth
Membre depuis le 02/24/16
780 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Leahy Spring 2016 Membre de l'équipe USF Tampa, Team 1-5, Leahy Spring 2016
USFT-LEAHY-S16S1G5
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 41
Total : 3,444
