Aller au contenu principal
Nutribullet Rx #NB-301 Drive Socket Replacement
Ce dont vous avez besoin
  1. Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: étape 1, image 1 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: étape 1, image 2 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: étape 1, image 3 de 3
    • Make sure to unplug the device before you start the repair.
    • Flip the blender over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the base of the blender.
    • Remove the base cover from the blender.
  2. Nutribullet Rx #NB-301 Drive Socket Replacement: étape 2, image 1 de 2 Nutribullet Rx #NB-301 Drive Socket Replacement: étape 2, image 2 de 2
    • Clamp down on the nut above the socket with the needle nose pliers so it stays in place for the next step.
  3. Nutribullet Rx #NB-301 Drive Socket Replacement: étape 3, image 1 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: étape 3, image 2 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: étape 3, image 3 de 3
    • Lay the blender on its side and hold the drive socket with the needle nose pliers to keep in from turning so you can remove the screw.
    • Use a Phillips #2 screwdriver to remove the screw securing the drive socket.
  4. Nutribullet Rx #NB-301 Drive Socket Replacement: étape 4, image 1 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: étape 4, image 2 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: étape 4, image 3 de 3
    • Remove the drive socket from the motor.
  5. Nutribullet Rx #NB-301 Drive Socket Replacement: étape 5, image 1 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: étape 5, image 2 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: étape 5, image 3 de 3
    • Remove all dust and residue from the area before you replace your new drive socket.
  6. Nutribullet Rx #NB-301 Drive Socket Replacement: étape 6, image 1 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: étape 6, image 2 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: étape 6, image 3 de 3
    • Use a Phillips #2 screwdriver to secure the drive socket to the motor.
  7. Nutribullet Rx #NB-301 Drive Socket Replacement: étape 7, image 1 de 2 Nutribullet Rx #NB-301 Drive Socket Replacement: étape 7, image 2 de 2
    • Place the bottom cover back on the blender.
    • Use the Phillips #2 screwdriver to replace the four 10 mm screws on the back cover back.
Martin G
Membre depuis le 03/05/24
145 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 7-3, Grodsky Spring 2024 Membre de l'équipe CSU Los Angeles, Team 7-3, Grodsky Spring 2024
CSULA-GRODSKY-S24S7G3
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 18
Total : 34
