Aller au contenu principal
Nvidia Shield Battery Assembly Replacement
Ce dont vous avez besoin
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: étape 1, image 1 de 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: étape 1, image 2 de 3 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: étape 1, image 3 de 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: étape 2, image 1 de 2 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: étape 2, image 2 de 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: étape 3, image 1 de 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: étape 3, image 2 de 3 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: étape 3, image 3 de 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: étape 4, image 1 de 1
    • Pull the battery apparatus out once all cables are removed.
5 autres ont terminé cette réparation.
Andrew Barbanera
Membre depuis le 09/20/14
376 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Hickman Fall 2014 Membre de l'équipe USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 membres
18 tutoriels rédigés
4 commentaires
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Réponse
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - Réponse
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - Réponse
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 28
Total : 6,517
