Aller au contenu principal
NVIDIA SHIELD Portable Motherboard Replacement
Ce dont vous avez besoin
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: étape 1, image 1 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: étape 1, image 2 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: étape 1, image 3 de 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: étape 2, image 1 de 2 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: étape 2, image 2 de 2
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: étape 3, image 1 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: étape 3, image 2 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: étape 3, image 3 de 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: étape 4, image 1 de 1
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: étape 5, image 1 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: étape 5, image 2 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: étape 5, image 3 de 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: étape 6, image 1 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: étape 6, image 2 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: étape 6, image 3 de 3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
3 autres ont terminé cette réparation.
Marc Perez
Membre depuis le 09/29/14
545 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Hickman Fall 2014 Membre de l'équipe USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 membres
18 tutoriels rédigés
Un commentaire
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 1,815
