Aller au contenu principal
Nvidia Shield Pro Android TV Controller Motherboard Replacement
Ce dont vous avez besoin
  1. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Bluetooth Controller Thumbsticks: étape 1, image 1 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Bluetooth Controller Thumbsticks: étape 1, image 2 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Bluetooth Controller Thumbsticks: étape 1, image 3 de 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 2, image 1 de 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 3, image 1 de 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 3, image 2 de 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 4, image 1 de 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 4, image 2 de 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 5, image 1 de 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 5, image 2 de 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: étape 6, image 1 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: étape 6, image 2 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: étape 6, image 3 de 3
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 7, image 1 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 7, image 2 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 7, image 3 de 3
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
  8. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Controller Motherboard: étape 8, image 1 de 1
    • After removing the triggers, your motherboard is completely separate and ready to be replaced.
Your motherboard is ready to be replaced.
Aidan Shelton
Membre depuis le 02/11/22
73 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 10
Total : 244
