Introduction
If your Nvidia Shield Pro Android TV is overheating, or you begin to hear a loud clicking noise when launching and using your device, use this guide to remove and replace your fan/heat sink. All you will need is a T6 Torx screwdriver and a plastic opening tool. You will not need to perform any difficult steps, but carefully detach the multi-colored wire.
Ce dont vous avez besoin
Flip to the back side of your Nvidia Shield Pro Android TV.
To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
Un commentaire
Hello can you tell me where to buy the fan and the plastic case opener?
