Aller au contenu principal
Nvidia Shield Pro Android TV I/O Board Replacement
Ce dont vous avez besoin
  1. Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: étape 1, image 1 de 2 Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: étape 1, image 2 de 2
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
  2. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: étape 2, image 1 de 3 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: étape 2, image 2 de 3 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: étape 2, image 3 de 3
    • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
    • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
  3. Nvidia Shield Pro Android TV I/O Board Replacement: étape 3, image 1 de 3 Nvidia Shield Pro Android TV I/O Board Replacement: étape 3, image 2 de 3 Nvidia Shield Pro Android TV I/O Board Replacement: étape 3, image 3 de 3
    • Detach the pack of wires by pulling it away from the socket.
  4. Nvidia Shield Pro Android TV I/O Board Replacement: étape 4, image 1 de 3 Nvidia Shield Pro Android TV I/O Board Replacement: étape 4, image 2 de 3 Nvidia Shield Pro Android TV I/O Board Replacement: étape 4, image 3 de 3
    • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
  5. Nvidia Shield Pro Android TV I/O Board Replacement: étape 5, image 1 de 2 Nvidia Shield Pro Android TV I/O Board Replacement: étape 5, image 2 de 2
    • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
  6. Nvidia Shield Pro Android TV I/O Board Replacement: étape 6, image 1 de 1
    • Gently pull the hard drive out of the device.
  7. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: étape 7, image 1 de 3 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: étape 7, image 2 de 3 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: étape 7, image 3 de 3
    • Detach the brown side of the connector from the I/O board by pulling it upward.
    • Remove the screw from the silver plate using a T6 Torx screwdriver.
    • Put the cable aside after removing it.
  8. Nvidia Shield Pro Android TV I/O Board Replacement: étape 8, image 1 de 2 Nvidia Shield Pro Android TV I/O Board Replacement: étape 8, image 2 de 2
    • Detach the small bundle of black wires from the I/O board by gently pulling upward.
    • Be very gentle because the wires are very fragile.
  9. Nvidia Shield Pro Android TV I/O Board Replacement: étape 9, image 1 de 2 Nvidia Shield Pro Android TV I/O Board Replacement: étape 9, image 2 de 2
    • Remove the three T6 Torx screws from the I/O board.
  10. Nvidia Shield Pro Android TV I/O Board Replacement: étape 10, image 1 de 3 Nvidia Shield Pro Android TV I/O Board Replacement: étape 10, image 2 de 3 Nvidia Shield Pro Android TV I/O Board Replacement: étape 10, image 3 de 3
    • Detach the multi-colored (red/yellow/black) wire from the I/O board by pulling it away from the socket.
  11. Nvidia Shield Pro Android TV I/O Board Replacement: étape 11, image 1 de 1
    • Gently remove the I/O board by sliding it away from the exterior input/output sockets on your Nvidia Shield Pro.
6 autres ont terminé cette réparation.
Jimmy Chen
Membre depuis le 01/23/20
615 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S18-G2, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 membres
6 tutoriels rédigés
2 commentaires
Where can I buy Nvidia Shield Pro Android TV I/O Board? Greentings from Brazil.
Sergio Santos - Réponse
Aniyone managed to get a source for this part, The IO board
Yoda Mann - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 19
30 derniers jours : 71
Total : 4,787
