Aller au contenu principal
Introduction
Use this guide to replace a broken or dead battery.
  1. Turn the laptop upside-down, with the handle facing away from you.
    • Turn the laptop upside-down, with the handle facing away from you.
  2. Pull the lock tabs towards the green outer edges of the laptop. Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. Lift up on the middle of the battery to remove it from the device. Lift up on the middle of the battery to remove it from the device.
    • Lift up on the middle of the battery to remove it from the device.
Robby Hubilla
Membre depuis le 24/01/2013
35 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-30, Amido Winter 2013 Membre de l'équipe Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 315
