Aller au contenu principal
OLPC XO-4 Touch Mouse Buttons Controller Replacement
Ce dont vous avez besoin
  1. OLPC XO-4 Touch Mouse Buttons Controller Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 2, image 1 de 2 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 2, image 2 de 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 3, image 1 de 2 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 3, image 2 de 2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Mouse Buttons Controller Replacement, Keyboard: étape 4, image 1 de 2 OLPC XO-4 Touch Mouse Buttons Controller Replacement, Keyboard: étape 4, image 2 de 2
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  5. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 5, image 1 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 5, image 2 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 5, image 3 de 3
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
  6. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 6, image 1 de 2 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 6, image 2 de 2
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
  7. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 7, image 1 de 2 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 7, image 2 de 2
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
  8. OLPC XO-4 Touch Mouse Buttons Controller Replacement, Lower Case: étape 8, image 1 de 2 OLPC XO-4 Touch Mouse Buttons Controller Replacement, Lower Case: étape 8, image 2 de 2
    • Close and flip the laptop over so you are looking at the battery compartment
    • Remove the five 4mm Phillips #1 screws from inside the battery compartment
  9. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 9, image 1 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 9, image 2 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 9, image 3 de 3
    • Flip the laptop over, showing the top of the device.
    • Open the laptop and rotate the screen ninety degrees.
    • Tilt the screen so the lower right corner of the screen is closer to the lower case.
  10. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 10, image 1 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 10, image 2 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 10, image 3 de 3
    • Push in and lift up on the keyboard edge of the white handle piece.
    • Pull the piece towards yourself to remove it from the laptop.
  11. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 11, image 1 de 1
    • Remove the four 4mm Phillips #1 screws attaching the green trim to the body of the computer.
  12. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 12, image 1 de 2 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 12, image 2 de 2
    • Pry off the rear green trim piece.
  13. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 13, image 1 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 13, image 2 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 13, image 3 de 3
    • Be careful not to pull the bottom portion of the laptop completely off, as there is a cable connecting it to the laptop.
    • Slide the green trim pieces away from the screen.
    • This should release the entire bottom portion of the laptop.
  14. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 14, image 1 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 14, image 2 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 14, image 3 de 3
    • Unplug the cable from the mouse buttons controller to completely remove the lower frame from the device.
  15. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 15, image 1 de 2 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 15, image 2 de 2
    • Rotate the entire lower assembly up slightly, and pull it away from the screen to free it from the screen hinge.
    • There may be some adhesive holding the cable to the metal plate. Gently pull the cable off of the plate if it is stuck.
  16. OLPC XO-4 Touch Mouse Buttons Controller Replacement, Mouse Buttons Controller: étape 16, image 1 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement, Mouse Buttons Controller: étape 16, image 2 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement, Mouse Buttons Controller: étape 16, image 3 de 3
    • You should now be looking at the bottom of the lower case.
    • Remove the eight 4mm Phillips #1 screws attaching the green trim pieces to the lower frame.
    • Pry off the front and side trim pieces.
  17. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 17, image 1 de 1
    • Remove the two 4mm Phillips #1 screws that attach the mouse buttons controller to the lower frame.
  18. OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 18, image 1 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 18, image 2 de 3 OLPC XO-4 Touch Mouse Buttons Controller Replacement: étape 18, image 3 de 3
    • Disconnect the ribbon cable attached to the keyboard compartment.
    • Unplug the ribbon cable between the touchpad and the mouse buttons controller.
    • Remove the mouse buttons controller from the device.
Michael Kellerman
Membre depuis le 01/24/13
58 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 3-30, Amido Winter 2013 Membre de l'équipe Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 319
