Aller au contenu principal
OLPC XO-4 Touch Screen Replacement
Ce dont vous avez besoin
  1. OLPC XO-4 Touch Screen Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Screen Replacement: étape 2, image 1 de 2 OLPC XO-4 Touch Screen Replacement: étape 2, image 2 de 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Screen Replacement: étape 3, image 1 de 2 OLPC XO-4 Touch Screen Replacement: étape 3, image 2 de 2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Screen Replacement, Screen Frame: étape 4, image 1 de 3 OLPC XO-4 Touch Screen Replacement, Screen Frame: étape 4, image 2 de 3 OLPC XO-4 Touch Screen Replacement, Screen Frame: étape 4, image 3 de 3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Screen Replacement: étape 5, image 1 de 3 OLPC XO-4 Touch Screen Replacement: étape 5, image 2 de 3 OLPC XO-4 Touch Screen Replacement: étape 5, image 3 de 3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Screen Replacement: étape 6, image 1 de 1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Screen Replacement: étape 7, image 1 de 2 OLPC XO-4 Touch Screen Replacement: étape 7, image 2 de 2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  8. OLPC XO-4 Touch Screen Replacement, Screen: étape 8, image 1 de 1
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
  9. OLPC XO-4 Touch Screen Replacement: étape 9, image 1 de 2 OLPC XO-4 Touch Screen Replacement: étape 9, image 2 de 2
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
  10. OLPC XO-4 Touch Screen Replacement: étape 10, image 1 de 3 OLPC XO-4 Touch Screen Replacement: étape 10, image 2 de 3 OLPC XO-4 Touch Screen Replacement: étape 10, image 3 de 3
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
  11. OLPC XO-4 Touch Screen Replacement: étape 11, image 1 de 1
    • Remove the screen from the laptop.
2 autres ont terminé cette réparation.
Zach Yasuda
Membre depuis le 01/24/13
173 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-29, Amido Winter 2013 Membre de l'équipe Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 membres
20 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 14
Total : 1,455
