Aller au contenu principal
Office Chair Gas Cylinder Replacement
Ce dont vous avez besoin
  1. Office Chair Gas Cylinder Replacement, Gas Cylinder: étape 1, image 1 de 1
    • Place the chair horizontally, putting it on its side.
  2. Office Chair Gas Cylinder Replacement: étape 2, image 1 de 1
    • The base is connected to the chair either with retaining clips or nuts and bolts at its center.
    • Remove the retaining clips or unscrew the nuts and bolts with a wrench or drill.
    • Remove the base of the chair.
  3. Office Chair Gas Cylinder Replacement: étape 3, image 1 de 1
    • Place a pipe wrench on the gas cylinder, and spray it with WD-40 to lubricate it and make it easier to remove.
    • Twist and pull the wrench to loosen the cylinder and remove it from its place.
  4. Office Chair Gas Cylinder Replacement: étape 4, image 1 de 1
    • Look up the chair's part number to find which gas cylinders are compatible with your chair.
  5. Office Chair Gas Cylinder Replacement: étape 5, image 1 de 1
    • Be sure to follow the instructions for your specific gas cylinder, since installation procedures may vary.
    • Place the tapered part of the cylinder into the column and rotate it into place.
    • Reconnect the base of the chair.
    • Place the chair upright and adjust the chair to your preferred height. Test it out by sitting on it.
Ligne d'arrivée
Christian Phillip
Membre depuis le 09/20/20
170 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G4, Woodhouse Fall 2020 Membre de l'équipe York University, Team S1-G4, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G4
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 30
30 derniers jours : 153
Total : 10,284
