Aller au contenu principal
Olympus Camedia D560 Rear Panel Control Buttons Replacement
Ce dont vous avez besoin
  1. Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: étape 1, image 1 de 2 Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: étape 1, image 2 de 2
    • Before disassembling your camera, be sure it is powered off.
    • Remove two screws from the video port located at the side panel of the camera.
    • Remove three screws from the bottom panel of the camera.
  2. Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 2, image 1 de 2 Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 2, image 2 de 2
    • Open the USB port cover, and remove three screws from inside.
    • Next, open the memory slot cover and remove the screw.
  3. Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 3, image 1 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 3, image 2 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 3, image 3 de 3
    • Use the blue opening tool to loosen and separate the back cover from the camera.
  4. Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 4, image 1 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 4, image 2 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 4, image 3 de 3
    • Locate and unscrew the three screws inside the back cover body (picture 3) .
    • Remove button pad assembly from the back cover.
  5. Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 5, image 1 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 5, image 2 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: étape 5, image 3 de 3
    • The button assembly is now separate from the back cover.
    • Inspect for broken areas. Replace or clean the button parts.
2 autres ont terminé cette réparation.
GradStudents2011
Membre depuis le 09/08/11
30 Réputation
3 tutoriels rédigés
Équipe
University of Maine, Team 1-27, Diaz Fall 2011 Membre de l'équipe University of Maine, Team 1-27, Diaz Fall 2011
UMAINE-DIAZ-F11S1G27
1 membre
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 1,062
