Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Olympus Camera Olympus SP550-UZ Battery Compartment Cover Replacement
      • Remove 6 screws : xD Memory Card Compartment: Open door, remove 2 screws inside. USB/AV Port : Open rubber flap on the opposite side of the body and remove 2 screws inside. Battery Compartment (Top): Open cover & remove screw located on top of battery housing. Bottom: Remove 1 screw near metal tripod socket (the one securing the casing frame).
      Demander à FixBot
      Ajouter un commentaire
      • Turn the camera so the battery compartment is facing uppermost (pointing upward). Grip the front and back plastic halves of the camera body. Gently and slowly ease the front and back pieces apart by about 3mm. *Note: Do not pull them entirely apart, as you only need a slight gap to free the hinge.
      Demander à FixBot
      • With a 3mm gap opened up, gently ease out one of the plastic hinge lugs attached to the battery compartment lid. Free the door entirely from the camera body. Take your replacement door and insert the lugs back into the loosened hinge slots.
      Demander à FixBot
      • Press the front and back camera halves firmly back together. Reinstall all six cross-head screws into their respective compartments.
      Demander à FixBot
Press halves of camera case together and replace the six screws.
John Smith
Membre depuis le 07/07/26
109 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 24
Total : 39
