Aller au contenu principal
Olympus D590 Motherboard Replacement
Ce dont vous avez besoin
  1. Olympus D590 Motherboard Replacement, Face Plate: étape 1, image 1 de 1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Motherboard Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Motherboard Replacement: étape 3, image 1 de 1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Motherboard Replacement: étape 4, image 1 de 1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Motherboard Replacement: étape 5, image 1 de 1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Motherboard Replacement: étape 6, image 1 de 1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Motherboard Replacement: étape 7, image 1 de 1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Motherboard Replacement, Motherboard: étape 8, image 1 de 1
    • Remove four screws holding the motherboard to the internal housing component using a Phillips #1 screwdriver.
  9. Olympus D590 Motherboard Replacement: étape 9, image 1 de 1
    • Be cautious of the wires attached to the motherboard.
    • Remove the motherboard from the internal housing component.
    • Do not completely lift the motherboard out with the wiring connected. The wires must be disconnected before proceeding. The next step will demonstrate disconnection process.
  10. Olympus D590 Motherboard Replacement: étape 10, image 1 de 3 Olympus D590 Motherboard Replacement: étape 10, image 2 de 3 Olympus D590 Motherboard Replacement: étape 10, image 3 de 3
    J'achète
    • Use rounded tweezers to disconnect the three wiring strips from the motherboard.
    • Using sharp tweezers may tear wiring tape and wires.
    • Use gentle force when wiggling or pulling wiring tape and wires to disconnect from the motherboard.
2 autres ont terminé cette réparation.
Sara
Membre depuis le 04/15/10
84 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 28-23, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 1,791
