Introduction
You must remove the batteries, the front casing, the rear casing, and the motherboard before removing the lens assembly.
Ce dont vous avez besoin
The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
Remove the 7 screws holding the front case in place, with a #00 screwdriver.
Six screws are 3.6 mm.
The seventh screw is 3.2 mm.
Pulling the front case off, requires applying enough strength in the right areas.
The front case snaps into place in three places:
At the top and bottom of the battery side (opposite of side pictured) of the case.
Right in the middle of the DC-in side (side pictured) of the case.
Top of the camera, to the left of the power button.
Once those places are disconnected, the front case will pop right off.
Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
