Introduction
The Olympus OM-D E-M10 Mark II flash replacement will depend on what component of the flash is broken. A soldering iron is required to repair the flash circuitry in every case. If wiring is broken at a point inside the main body of the camera, the camera body's circuitry must be exposed (see Olympus OM-D E-M10 Mark II Motherboard guide).
If the issue is in the flash LED then only the silver flash casing needs to be removed. A multimeter is recommended for identification of the area in need of replacement.
Ce dont vous avez besoin
Lay the camera on its back as shown. Using the button located to the right of the lens, hold it down while rotating the lens to release it from the camera.
See the Olympus OM -D E-M10 Mark II guide for motherboard replacement and follow the guide until the motherboard is exposed
