Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Olympus Pen E-PL7 LCD Screen Replacement
Ce dont vous avez besoin
  1. Olympus Pen E-PL7 LCD Screen Replacement, Battery: étape 1, image 1 de 2 Olympus Pen E-PL7 LCD Screen Replacement, Battery: étape 1, image 2 de 2
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 LCD Screen Replacement, LCD Screen: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  3. Olympus Pen E-PL7 LCD Screen Replacement: étape 3, image 1 de 2 Olympus Pen E-PL7 LCD Screen Replacement: étape 3, image 2 de 2
    • Fully extend the LCD assembly.
  4. Olympus Pen E-PL7 LCD Screen Replacement: étape 4, image 1 de 3 Olympus Pen E-PL7 LCD Screen Replacement: étape 4, image 2 de 3 Olympus Pen E-PL7 LCD Screen Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top LCD bracket.
  5. Olympus Pen E-PL7 LCD Screen Replacement: étape 5, image 1 de 3 Olympus Pen E-PL7 LCD Screen Replacement: étape 5, image 2 de 3 Olympus Pen E-PL7 LCD Screen Replacement: étape 5, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may fall off after the screws have been removed.
  6. Olympus Pen E-PL7 LCD Screen Replacement: étape 6, image 1 de 3 Olympus Pen E-PL7 LCD Screen Replacement: étape 6, image 2 de 3 Olympus Pen E-PL7 LCD Screen Replacement: étape 6, image 3 de 3
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  7. Olympus Pen E-PL7 LCD Screen Replacement: étape 7, image 1 de 2 Olympus Pen E-PL7 LCD Screen Replacement: étape 7, image 2 de 2
    • Use tweezers to peel back the plastic cover.
  8. Olympus Pen E-PL7 LCD Screen Replacement: étape 8, image 1 de 3 Olympus Pen E-PL7 LCD Screen Replacement: étape 8, image 2 de 3 Olympus Pen E-PL7 LCD Screen Replacement: étape 8, image 3 de 3
    • Use a spudger to flip back the black bar on the LCD Ribbon ZIF connector.
  9. Olympus Pen E-PL7 LCD Screen Replacement: étape 9, image 1 de 2 Olympus Pen E-PL7 LCD Screen Replacement: étape 9, image 2 de 2
    • Gently pull the ribbon cable out with tweezers.
  10. Olympus Pen E-PL7 LCD Screen Replacement: étape 10, image 1 de 1
    • Remove the LCD Screen.
6 autres ont terminé cette réparation.
Kelsea Weber
Membre depuis le 11/12/15
21 222 Réputation
32 tutoriels rédigés
10 commentaires de tutoriel
Magnifico
Great Work!!
apuntotres - Réponse Partager
Where can I buy a replacement LCD screen?
Joshua Almeida - Réponse Partager
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
josollis - Réponse Partager
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
Stephan Fagerer - Réponse Partager
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
ah to lee - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 34
30 derniers jours : 138
Total : 13,041
