Aller au contenu principal
Olympus Stylus 1030 SW Flash Assembly Replacement
Ce dont vous avez besoin
  1. Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: étape 1, image 1 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: étape 1, image 2 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: étape 1, image 3 de 3
    • Remove the three screws in the corner of the front plate using a Phillips #00 screwdriver.
    • Lift up on the plate until it comes off the rest of the camera.
  2. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 2, image 1 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 2, image 2 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 2, image 3 de 3
    • Use the Phillips #00 screwdriver to remove the two screws on both of the side plates of the camera.
  3. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 3, image 1 de 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera.
  4. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 4, image 1 de 2 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 4, image 2 de 2
    • Turn the camera so the short side without the av port is facing you.
    • Remove both of the screws on this side using the Phillips #00 screwdriver.
    • Remove the front case.
  5. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 5, image 1 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 5, image 2 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 5, image 3 de 3
    • Face the camera so the short side with the AV port facing you. Use your Phillips #00 screwdriver to remove the single screw.
    • Turn your camera so the other short side is facing you. Use the Phillips #00 screwdriver to remove the two screws on the silver parts.
    • Face the bottom of your camera towards you and remove the single screw using the Phillips #00 screwdriver.
  6. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 6, image 1 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 6, image 2 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 6, image 3 de 3
    • Open the battery door and use your Phillips #00 screwdriver to remove the screw in the middle of the opening.
    • Use the spudger to pry at the rear case until it comes off.
  7. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 7, image 1 de 2 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 7, image 2 de 2
    • Flip the camera so the front is facing you.
    • Use your Phillips #00 screwdriver to remove the three screws located in the corners on this side.
  8. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 8, image 1 de 1
    • Turn the camera so you are looking at the top.
    • Use your Phillips #00 screwdriver to remove the single screw.
  9. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 9, image 1 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 9, image 2 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 9, image 3 de 3
    • Use your spudger to gently pry at the side of the LCD screen and the cover over it.
    • Gently take it apart, using caution with the motherboard and battery.
  10. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 10, image 1 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 10, image 2 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 10, image 3 de 3
    • Use your Phillips #00 screwdriver to remove the three screws.
  11. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 11, image 1 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 11, image 2 de 3 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 11, image 3 de 3
  12. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 12, image 1 de 1
    • Pull the foam to the side gently and use your Phillips #00 screwdriver to remove the single screw.
  13. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 13, image 1 de 1
    Outil utilisé dans cette étape :
    • Use your tweezers to gently pull the motherboard out of the camera.
  14. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 14, image 1 de 2 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 14, image 2 de 2
    • Use your Phillips #00 screwdriver to remove the two screws holding the wires to the flash assembly.
  15. Olympus Stylus 1030 SW Flash Assembly Replacement: étape 15, image 1 de 2 Olympus Stylus 1030 SW Flash Assembly Replacement: étape 15, image 2 de 2
    • Use your tweezers to gently remove the last wires connected to the flash assembly.
Paige Asmus
Membre depuis le 03/24/23
241 Réputation
1 tutoriel rédigé
Équipe
Casper College, Team 1-4, Lareau Spring 2023 Membre de l'équipe Casper College, Team 1-4, Lareau Spring 2023
CASC-LAREAU-S23S1G4
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 84
