Aller au contenu principal
Olympus Stylus 410 Slider Replacement
Ce dont vous avez besoin
  1. Olympus Stylus 410 Slider Replacement, Slider: étape 1, image 1 de 1
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Slider Replacement: étape 2, image 1 de 1
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 Slider Replacement: étape 3, image 1 de 1
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 Slider Replacement: étape 4, image 1 de 1
    • The slider should now be free from the body of the camera.
Jared Ruekberg
Membre depuis le 04/15/10
33 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-13, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 membres
17 tutoriels rédigés
2 commentaires
Camera would not turn on nor lens extend. Took slider off per instructions and cleaned the switch and was able to rotate switch back and forth to turn camera on and off by hand. Reassembled slider and could turn camera on but not off. Disassembled again and find the rotating switch is permanently stuck in counter clockwise position and cannot be activated by hand. I do not want to force the switch because it did operate very easy. What can be the trouble?
rraff8300@sbcglobal.net
Richard Rafferty - Réponse
Excellent instructions for removing stylist 410 slider. Hope you can help with my prior stuck switch problem.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 15
Total : 3,549
