Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Removing the back case from the speaker is relatively easy. Once you unscrew the four back screws, there is a wire that is attached to the back case. Before pulling the back case completely off, disconnect the wire from the back case by carefully pulling it out with tweezers. This will allow the back case to be completely removed from the device.
  1. Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device. Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  4. Use a magnet to remove the screws after unscrewing them and place them aside. Use a magnet to remove the screws after unscrewing them and place them aside.
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  5. Carefully remove the back cover without breaking the battery wire.
    • Carefully remove the back cover without breaking the battery wire.
  6. Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers. The battery is still attached to the back cover.
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
3 autre(s) ont terminé cette réparation.
Andrew Entwistle
Membre depuis le 17/02/2016
679 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 2-2, Sullivan Spring 2016 Membre de l'équipe USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 586
