Aller au contenu principal
Omaker M4 Battery Replacement
Ce dont vous avez besoin
  1. Omaker M4 Battery Replacement, Back Case: étape 1, image 1 de 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Battery Replacement: étape 2, image 1 de 2 Omaker M4 Battery Replacement: étape 2, image 2 de 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Battery Replacement: étape 3, image 1 de 2 Omaker M4 Battery Replacement: étape 3, image 2 de 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Battery Replacement: étape 4, image 1 de 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Battery Replacement: étape 5, image 1 de 2 Omaker M4 Battery Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Battery Replacement, Battery: étape 6, image 1 de 3 Omaker M4 Battery Replacement, Battery: étape 6, image 2 de 3 Omaker M4 Battery Replacement, Battery: étape 6, image 3 de 3
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
3 autres ont terminé cette réparation.
Carlos Pernia
Membre depuis le 02/10/16
170 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 2-2, Sullivan Spring 2016 Membre de l'équipe USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
3 membres
2 tutoriels rédigés
Un commentaire
What battery is required for this though? Is it easily found on amazon?
Mohsin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 1,345
