Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
When using the metal spudger to remove the battery, be sure to carefully pry along the entire side the battery so that the battery will come off without bending.
  1. Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device. Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Use a magnet to remove the screws after unscrewing them and place them aside. Use a magnet to remove the screws after unscrewing them and place them aside.
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Carefully remove the back cover without breaking the battery wire.
    • Carefully remove the back cover without breaking the battery wire.
  5. Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers. The battery is still attached to the back cover.
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover. Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover. Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
3 autre(s) ont terminé cette réparation.
Carlos Pernia
Membre depuis le 10/02/2016
170 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 2-2, Sullivan Spring 2016 Membre de l'équipe USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 845
